MAFT LTFT's - -4 or +0.2 better?
So, is -4.x close enough? I'm going to put some more miles on it tonight to see if it gets any better at +15 base.
O2S1's & LTFT's: How close should B1 & B2 be to one another? What's a large difference and what can cause it? I've heard having LTFT's slightly negative is better than exactly at zero. But is -6.9 too far below zero?
TPS: Should idling while stopped always have this value at 0.0%? I've seen it intermittently going to 0.4% and 0.8% while stopped & idling.
Timing: My timing doesn't seem to be fantastic for a '98 H/C/I car. How much timing should I be seeing over which RPM ranges in both closed and open loop? I presume the only way to now get more timing is further PCM programming?
KR: How close to zero is considered not worth the hassle to tweak? What's each degree of KR worth from a performance standpoint?
[ January 30, 2002: Message edited by: JimMueller ]</p>
<strong>OK, ran it some more last night and the LTFT's dropped to -6.9 average. So I changed the base back to +10, and after a 90 minute trip it's back to an average of 0.099. O2S1B2 is consistently ~0.035 higher than O2S1B1.
O2S1's & LTFT's: How close should B1 & B2 be to one another? What's a large difference and what can cause it? I've heard having LTFT's slightly negative is better than exactly at zero. But is -6.9 too far below zero?</strong><hr></blockquote>
The difference in B1 and B2 you see isn't anything to worry about. After my Heads and Cam I was seeing 2.xx difference in banks.
If you run your LT's at Negative 6.9 you are running it rich and the computer is correcting. I got good results tuning it either way, rich or lean no more than 5.0 - 7.0, so you're okay. Just don't leave them off in the high teens, that's alot of correcting by the PCM, but you don't have to get them to 0.
[quote]<strong>Timing: My timing doesn't seem to be fantastic for a '98 H/C/I car. How much timing should I be seeing over which RPM ranges in both closed and open loop? I presume the only way to now get more timing is further PCM programming?<hr></blockquote></strong>
This really depends on if you see any KR, and some other stuff, what numbers are you seeing at WOT?
[quote]<strong>KR: How close to zero is considered not worth the hassle to tweak? What's each degree of KR worth from a performance standpoint?<hr></blockquote></strong>
This is where I would be very ****. I luckily never got any KR except for when i had the case of y-pipe banging. I read before, but cannot verify that each degree of KR will take something like 4hp off a stock car. I believe this number changes though when more is take out, do 2 degrees of KR would be >8hp.
I do know that some people have false knock, but I don't know what mods you have, so we can't even begin to talk about that and how to diagnose it.
Maybe someone will correct me if I'm wrong on this.
[ January 30, 2002: Message edited by: HalfMoon ]</p>
Mods:
FTRA, FRA, FRA2, K&N 33-2118, Whisper Lid, Whisper MAF Ends, LS6 intake manifold, CNC cylinder Heads 2.02/1.57, Comp Cams 218/226 527/535 112, NGK TR55's @ .050, Grotyohann headers/Y-Pipe/CarSound cats, Flowtech 3" cutout, Ed Wright tuning, SPEC Stage II clutch.
My timing is 23-25 for short bursts at WOT. Haven't had a chance to wind out a full gear.
KR: Logs indicate random single instances of 2-4* of KR, typically around 5K or below 2K. However, I intermittently hear what I think is audible detonation above 5K. How much KR would it take to make it audible?
Ed Wright told me most LS1's make the most power on the dyno at 13:1, but like 12.9:1 on the track due to additional loading. What's 12.9:1 approximately equal to on our O2's? .87-.88?
However, all the online documents indicate 12.5-.6 make the most power. Whom do you believe?
I tune for 13:1 AF and feel that the pcm will adjust for the real world load conditions of being at the track.
I messed around with my BASE and WOT with the MAF T last week at the track. Regardless of the settings, I still saw 28-29 degrees of timing is what my pcm is programmed for...
I have been told that best performance is get the Ltrims to zero or in that ballpark... +/- 5%.
I also tune by ear sometimes... And I also have an AF gauge.
I'd go .870's.
