ported SLP maf and MAF calibrations
stock runs like this:
rpm 1500 1625 1750 1875
flow gm/sec 2.46 2.86 3.29 3.77 .... etc..
So since the SLP MAF is about 15% larger should I increase those values across the board by 15%???
"No, the SLP MAF is calibrated at the MAF so it works as you would a stock
MAF. You can play with the values to fine tune the MAF, but if you to use
the truck MAF table that Ken supplied, you have to use an total STOCK 85mm
MAF. NOT an SLP, GMS or PACE calibrated 85mm version."
