Quick ? about 135 code.
Old Dec 11, 2005 | 07:56 PM
Torqued's Avatar
Default Quick ? about 135 code.
When this code is set is fuel economy or drivability affected?
Thanks
Old Dec 12, 2005 | 08:21 AM
rtr2001ss's Avatar
I'm getting the 155, which is bank 2 sensor 1, so same thing but other side. I don't know if anything is affected, doesn't seem like it. I'm wonding if I should just replace the O2 sensor.
Old Dec 12, 2005 | 11:19 AM
WS6FirebirdTA00's Avatar
p0135 and p0155 are common codes with headers, its because the o2s are not getting hot enough in the time alloted for the test to be run. i turned my code off for those. it will not effect anything as long as they oscillate well once warmed up. now if they never heat up then you ahve a bad o2. but only way to really tell is to scan it
Old Dec 13, 2005 | 10:20 AM
Torqued's Avatar
Thanks.
Old Dec 13, 2005 | 05:03 PM
2001 White Ws6's Avatar
I'm setting of the P0135 code so should i replace with another O2 sensor or just leave it be since it doesn't affect anything. Also i keep hearing that the vette O2 sensors are better...is that right?
Old Dec 13, 2005 | 06:28 PM
i have an o2 for sale , pm me if you want it. its a lot cheaper than a new one and its not an old sensor.
