how to tune IAC?
1) How do you tune IAC with HP Tuners? I checked redhardsupra's site, and it said that you want your IAC to be ideally 50, but less than 70. Mine is at 94, but he doesn't say how to change.
2) How do you properly tune with AC on? I didn't see anything at redhard's site about that either. Please lmk thanks.
Also can't you adjust your IAC through HP Tuners without changing the set screw? I heard somewhere along the way was bad to change set screw.
1) How do you tune with AC on?
2) Cruise mode, I was driving down highway other day, and when I went to shift gears, car was bringing rpm's up to 2k, then when in gear was fine. What do you do to adjust that? When driving around the city is fine.
