LS1 Edit Questions?
Old Feb 25, 2002 | 11:38 AM
SAM98WS6's Avatar
Default LS1 Edit Questions?
Can you guys clarify the rpm limits can be adjusted 7000-7200 rpms? Web site says 5 rpm limits and then limits by gear table, temp and delay. This sounds perfect to fix the A/F ratios and Knock Retard.
Any unsatisfied customers out there?
I am looking forward to getting the locked version for my 98 ARE Stage 2 car with T1 cam and stock pcm. Can I get it locked for 2 pcms (98 & 02) and when the 02 is available get the updated software free of charge?
Thanks
Old Feb 25, 2002 | 06:46 PM
227Hawk's Avatar
Default Re: LS1 Edit Questions?
Other part of question, Yes they will VIN.
lock now and 02 upgrade upon availability
Old Feb 26, 2002 | 12:09 AM
SIR's Avatar
SIR
You can adjust you rev limits numerous ways.
Rev limit by gear <-- one you will use the most
Rev limit by temp
REv limit by delay
Also, park/neutral
bad vss
ETC limit
You can raise or lower you rpm limit to whatever number you desire.
oh yeah you can also adjust the number that "resusmes." Ex: cutoff at 6500 and reusme at 6499
[ February 25, 2002: Message edited by: SIR ]</p>
Old Feb 26, 2002 | 02:18 PM
SAM98WS6's Avatar
thanks guys!
