stock to 42lbs need % for ls1edit
Old Feb 26, 2002 | 03:45 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default stock to 42lbs need % for ls1edit
I think they flow more then 42lbs at 60 psi. If someone could tell me what I should give them for % wise.
Thanks
Old Feb 26, 2002 | 06:41 PM
sross's Avatar
Default Re: stock to 42lbs need % for ls1edit
Here's how I did it. I'm not sure if it's the best way but it got me really close...
I figured out what my replacement injectors flowed at a certain PSI (or kPa) and then figured out what the stockers flowed at the same PSI (or kPa). Then I divided the two and multiplied the numbers in the stock table by the result. For example, in your case if you've got a '98 (stock with 28 lb/hr injectors), you'd divide 42/28 and get 1.50. Now just multiply the numbers in the injector flow rating table by 1.5.
Like I said, I don't know if that's the best way but it worked for me.
Old Feb 26, 2002 | 07:27 PM
sross's Avatar
By the way, the "edit entire table" function didn't seem to work very well for me. I did each cell manually.
Old Feb 26, 2002 | 08:55 PM
KenK's Avatar
The edit whole table should work, Remember it is in percent, so to mutiply the whole table by 1.5, You would enter 150, for 150%, then hit the multiply button.
KenK
Old Feb 26, 2002 | 09:29 PM
sross's Avatar
Yes, you're right Ken. User error...
Old Feb 27, 2002 | 07:09 PM
Mr Cowl Hood's Avatar
[quote]Originally posted by sross:
<strong>Here's how I did it. I'm not sure if it's the best way but it got me really close...
Like I said, I don't know if that's the best way but it worked for me.</strong><hr></blockquote>
I agree 100%. That's what I do, except you may have to play with it a bit to see if you want to keep that sloped curve or flatten it out. Some cars ran better with the Injector offset curve as a straight line.
That's why each is different and there are no absolutes.
[ February 27, 2002: Message edited by: Mr Cowl Hood ]</p>
