MAFT vs. custom tune
A custom tune changes, not only, fuel tables but adds timing. LS1's can run a lot more timing than they have from the factory too! A good custom tuner could make you a deal to work with you and your future mods as well.
Buying LS1 edit could work for you as well, but that depends on how comfortable you are with the knowledge of your car. Engines get expensive if blown apart. There's a lot of info on these message boards to learn from. The learning curve could take a while too.
Good Luck! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Get a car up to full operating temp...set the maft and it wont revert back to prior settings. A maft modifies the output signal of the MAF to the pcm. Think of it like an OLD bathroom scale <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> When you arent on the scale, a lot of them wont return to zero lbs. They would show like 5lbs with nothing on the scale. You always had that little dial on the scale to skew the reading back to show zero lbs. Now the scale LOOKS right to you but we all know that the calibration is a little off. The scale=maf....dial=maft .... the maft skews the maf signal so it looks "right" to the pcm. Its that simple.
MAF T can only really be used to adjust your A/F ratio and even then in a very rudimentary fashion.
I had one and just ditched it since it was a temporary solution.
thanks,
Chris
