I can't change my shift points
Old Mar 23, 2002 | 07:17 PM
KOOL C5's Avatar
Default I can't change my shift points
First it was no changing for gears and tire ratios, now it won't let me change shift points. I'm having lots of tuning problems also, but I need to figure out one thing at a time. The Ls1 edit doesn't seem to have the same options on the Vette as the F Bodies. I need some more help. Thanks.
Tom
Old Mar 23, 2002 | 07:49 PM
ChrisB's Avatar
Default Re: I can't change my shift points
what do you mean like it "won't let you" - does the software not let you make changes to your shift points, or are the changes you make not seeming to work?
Old Mar 23, 2002 | 09:15 PM
KOOL C5's Avatar
Chris
You can make changes and apply them, but when you look at it again it's always back where is was at the start. I also get a P1518 code after I program the PCM. Is that normal?
Tom
Old Mar 23, 2002 | 10:37 PM
KOOL C5's Avatar
I figured it out. I wasn't doing it right.
I'm still wondering about the code. It's a no comm from the PCM to the TAC Module.
Tom
Old Mar 24, 2002 | 10:39 AM
ChrisB's Avatar
Kool: I believe that code is normaly - or at least I alway get it also. I usually just clear all codes after a pcm flash (and before if there are any).
Old Mar 24, 2002 | 11:04 AM
ToplessTexan's Avatar
Gear scaling is coming in 1.05. I was disappointed it wasn't in 1.04 since Dave assured me it was, as well as all other advertised features, prior to purchase.
