Auto Tap Question
Old Mar 26, 2002 | 07:08 AM
Vettepartz's Avatar
Default Auto Tap Question
For the first time, I tried to run a log on autotap and I get a 14-52 "Bad file name" error and it locks up. I emailed the Atapp people and they didn't reply. Anyone else have this problem, and is there a fix for it?
Old Mar 26, 2002 | 07:19 AM
jpatrick's Avatar
Default Re: Auto Tap Question
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Vettepartz:
<strong>For the first time, I tried to run a log on autotap and I get a 14-52 "Bad file name" error and it locks up. I emailed the Atapp people and they didn't reply. Anyone else have this problem, and is there a fix for it?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm not sure what to do to fix the problem, but I do know that the Autotap tech support person, Joe, was out sick yesterday and wasn't able to follow up on any questions.
Jeff
Old Mar 26, 2002 | 07:37 AM
BillC99SS's Avatar
Since you didn't tell us what you tried to name your log file, it's going to be hard to diagnose.
IF you are using the DOS version, the name can only be 8 characters long with NO spaces or other illegal DOS file characters (periods,slashes,etc.).
Bill
Old Mar 26, 2002 | 07:52 AM
Vettepartz's Avatar
I am using the windows version and I named the file first . Just four letters.
Old Mar 26, 2002 | 08:20 AM
Vettepartz's Avatar
Let me re-phrase that.
I named the file "first" (without quotes).
Old Mar 26, 2002 | 02:32 PM
BillC99SS's Avatar
I can't remember ... do you need to include the file "Extension" (xxxx.atl) when you name the log file?
As above, be sure you didn't accidentally include a trailing space in the log name (xxxx .atl). It's easy to do.
Bill
<small>[ March 26, 2002, 09:43 PM: Message edited by: BillC99SS ]</small>
Old Mar 27, 2002 | 07:22 AM
Vettepartz's Avatar
After posting this, Joe from AutoTap got back to me right away. It's good to see a quick response from a manufacturer. Kudos to A-Tap
Old Mar 27, 2002 | 07:26 AM
Chris Jones's Avatar
What's the fix? Mine does that too, on two different computers.
I'm beta testing EFILive this weekend, assuming it works then I won't be using Autotap anymore. The EFIlive that I'm testing works with the Autotap interface. Cool! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
 Michael S. Palmer
Old Mar 28, 2002 | 07:25 AM
Vettepartz's Avatar
Chris, here is what I did to make it work:
From a table you have set with parameters, click on the 'log' tab'. Then select 'Create File'. Give it a name and hit save. This creates an EMPTY file where the logged info will be saved. Now hit the space bar and a red border will come up and you will start logging the info. When you hit the space bar again it will stop.
When you select the log tab, dont use the "Stop/Start Space' function. That is what was fouling me up. Good Luck
