Should I take off torque management or not?
Old Dec 20, 2005 | 05:53 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Originally Posted by solocam
On a stock motor the T/M is hardly noticable. But on a modded motor. The car will feel like you slammed on the brakes during the shifts, so you have to remove it.
That may be true, but changing to a higher stall TC 5
years ago gave me an a$$load of TM on the 1-2 shift.
(no tuning except HPP3).
Old Dec 21, 2005 | 07:38 AM
1BAD98TA's Avatar
I would be curious to see what the track results would be before and after TM.. That would be the only real way to know exactly how bad its hurting performance.. If its only a hundreth of a second difference then I will just leave mine alone.. if its going to give me a tenth.. then maybe its worth it
Old Dec 21, 2005 | 08:35 AM
ARCTICWHITE98Z28's Avatar
I would be interested in seeing those results also. Has anyone ever ran the 1/4 before and after TM was removed???
Old Dec 21, 2005 | 09:43 AM
jxaxsxoxn's Avatar
Before time on my car was 13.6. After the shift kit only (no other trans mods) Jimmyblue reduced my tm and messed with the power enrichment it ran 13.2.
Since then I got HPTuners myself and deleted all the TM.
I plan on going to the track someday and trying a bunch of different tunes.
Could try bone stock and without.
I don't think it's going to be good because I hit TM 100% stock at least twice during some aggresive highway passing, it was like the ignition shut off.
And it was at maybe 75-80 mph, 100% tps so it wasn't the rev limiter.
Old Dec 21, 2005 | 10:16 AM
DrkPhx's Avatar
I removed TM over two years ago with no problems. The person who rebuilt it said the trans was in good shape especially considering it had 62K miles and over 130 track runs.
The most noticeable thing TM does is pull several degrees of timing at each shift point during WOT. Any datalogging software will show this.
