ls1-edit and emmissions question....
Old Mar 27, 2002 | 10:15 PM
Slow Z28's Avatar
Default ls1-edit and emmissions question....
alright, so they've gone to a kick *** test here in the milwaukee, WI area... they just plug into the diagnostics port to read the computer and see if any codes are thrown to determine if you pass or fail. like you can get away with running no cats if you have o2 sims. so....
when you turn off the codes for the rear o2's to run off road pipes, or the EGR removal, etc....what would happen when that scanner is hooked up? would it still throw a code? or would you pass because no code is being thrown that is visable to the operator? thanks
Chris
Old Mar 28, 2002 | 02:28 AM
Black LS1 T/A's Avatar
Moderator
Default Re: ls1-edit and emmissions question....
If codes are turned off, it is detected.
I think there is some speculation that two codes are allowed. Check the document and tell us what you think:
http://www.epa.gov/otaq/regs/im/obd/r01015.pdf
