Replacing 02 simms, going with a cat, need opinions
This is after getting f'ed up reading on diagnostic computer and auto tap
Welp Here are the results... I ended up getting the Computer replaced today. Free of charge (dont ask). There was high voltage going to the computer , therefore kinda frying it. There was also corrosion buil up from the wire to the computer. That was cleaned up and new computer was put on. The simms have been taken off and regular sensors hooked back up. The diagnostic reading turned out to be normal after everything was swapped, however the SES light will still be set off soon cause i still dont have cats. What I am gonna go ahead and do is have a cat (1) put on tomm. for $160. The guy told me it was a 2 chamber (3 inch)cat and should give good readings after installation. Just wondering if yall had any thoughts, cause it is a little starnge I am just having one put on as opposed to 2. So instead of having 2- 2.5 inch cats, I am having 1- 3 inch cat put on. (past the Y-pipe). Sound strange?
My gut feeling is that two 2.5 inch cats in parallel is less restrictive than one 3" cat, but there is already the 3" pipe, so who knows?
