Everyone with a MAFT
Old Mar 30, 2002 | 10:01 PM
thxone's Avatar
Default Everyone with a MAFT
I have heard reports that the ECM will eventually learn any new corrections made to the MAFT. Is this true? And is buying a MAFT actually worth it?
Old Mar 30, 2002 | 10:12 PM
Slow Z28's Avatar
Default Re: Everyone with a MAFT
from my understanding, that isn't possble, because...
the computer is being sent information by the MAF sensor, but the signal is interrupted by te maf translator to compensate for your personal settings. so the computer is still being sent a signal, just a "massaged" signal for your car. really isn't a way to learn back to stock with that. hope that helps
Chris
Old Mar 31, 2002 | 09:19 PM
Slowhawk's Avatar
LS1Tech Sponsor
The computer does learn the idle and part throttle in order to achieve the 14.7-1 A/F for idle and cruising.Which is very good.
Most people use the MAFT to get L-terms in as close to 0 at WOT to help tune the A/F.
From around 3000rpm up,the computer locks a table for fuel(open loop).With a MAFT you can tune a richer or leaner mix for WOT and the computer will not change this.
There are more in depth threads on this board you should look into.
Old Apr 4, 2002 | 09:28 PM
NOBR8KSS's Avatar
True...your computer will "relearn"...in other words, at part throttle it will adjust the A/F mix to 14.7:1 as long as it is within the PCMs range to do so.
With a MAFT, at the Base setting, you are trying to make the PCM do as little work as possible at correcting the A/F ratio...that is your goal in getting the LTFTs as close to zero as possible.
Once you get the Base setting consistent around 0, you can adjust the WOT setting, which the computer will NOT relearn..it is based on a fuel map which is programmed into the PCM...you can use the MAFT to tell the computer false information to get O2s around .890-.900 mv. If that makes any sense....
