MAFT and Nitrous - kinda long
Conditions at the track (weather primarily) will make a big difference! I adjust my maft at the track for max performace given the weather. It's also helpful becuase I can run different maft settings when not running on the juice.
Best advice if you won't be able to monitor your performance - you'll have to errr heavy on the side of richness. Don't set it up on the dyno to run "just right" like you would be inclined to do. Run it rich.
BTW: you don't need a laptop and AutoTap/Ease to monitor (although that's the best way). A ScanMaster would do well on monitoring parameters or at least an A/F ratio gauge if nothing else (couldn't monitor KR though which is one of the things you'l want to keep your eye on).
Hope this helps!
Mark
Try to get your BASE adjusted so that your LTRIMS are reading about -2 on both banks. Get your WOT to the .910 range and then head to the dyno to fine tune from there.
Good luck,
Chris
