LS1 Edit & Torque Managment Hell !
Old Apr 9, 2002 | 10:03 PM
Zero2Sixty's Avatar
Default LS1 Edit & Torque Managment Hell !
Well, It seems I may have overlooked one thing when I ordered my torque convertor and transgo shift kit and that would be the dreaded evil bastard - the one and only "Torque management".
I've been told that a local shop will have the LS1 edit for the 2001/2002 engine here in the next 4-5 weeks and will provide dyno/PCM programming.
** SO **
Exactly what items should I have the speed shop remove/adjust based on the mods I currently have ?
Thanks in advance !!! I really appreciate any feedback you have.
2001 Z28 Monterey Maroon :
Fully Loaded, 3.23 Performance Axle, A4, Corsa Performance,
Shaner S2 Ported+Polished Throttle Body,Throttle Body Bypass, Throttle Body Bump Stop,
FRA, K&N Fuel Injection Performance Kit-2, 17x9.5 Torque Thrust II's w/ BFgoodrich G-force KDW,
BMR Shock Tower Brace, BMR Front & Rear Sway bars, BMR Boxed Subframe connectors, Baer Eradispeed Rotors,
Custom Mandrel Y-pipe
Awaiting Install :
PI Vigilante 2800 (2.5str), B&M Supercooler 19K GVM, BMR Boxed LCA's, BMR Adjustable PHB,
BMR Relocation Brackets, Gaugeworks dual pod (full pillar), Autometer Carbon Fiber Trans Temp & Water Temp, Bilstein HD's revalved (Strano), Eibach pro-kit.
