How does the PCM determine misfires?
Old Apr 12, 2002 | 03:10 PM
Magnus's Avatar
LS1TECH Sponsor
Default How does the PCM determine misfires?
The PCM can determine if a particular cylinder is having issues, but how?
How does it know its cyl 1 and not cyl 3?
Old Apr 12, 2002 | 07:30 PM
Team ZR-1's Avatar
Default Re: How does the PCM determine misfires?
In simplest form there is a crank and a cam position sensors, between the two the PCM can determine which piston and stoke.
It is not a perfect circuit and is known to be flawed even by EPA which required the misfire watchdog to protect the cats.
The crank sensor looks for any change in crank rotation and assumes it is misfire but other things can cause crank change such as a warped rotor, ABS, and even a crank pulley that is not
properly balanced, esp undersized ones which will trigger misfire counters.
Old Apr 13, 2002 | 07:29 AM
LS1derfull's Avatar
John is right, but pcm looks at velocity changes in piston travel which it measures with cam/crank sensors, any uneven loading from drivetrain can disturb crank speed but pcm has allowances for slight momentary changes in crank inertia.
Old Apr 15, 2002 | 08:34 AM
Magnus's Avatar
LS1TECH Sponsor
Wow. I didn't realize it was that complex.
Thanks for the info.
