PO102 code????
Old Dec 22, 2005 | 05:31 PM
whiteLS1's Avatar
Default PO102 code????
maf or vaf low circuit singnal.
i replaced the maf and still wont get rid of code. reset computer and also put car on HP tuners and maf is not reading.
please help need ideas
Old Dec 22, 2005 | 06:38 PM
SRPerformance's Avatar
Check the wirring to the MAF?
Old Dec 22, 2005 | 06:52 PM
RedHardSupra's Avatar
when you insert the MAF signal into the scan table, do you get any sensible readings or is it stuck at 0? are you supposed to be in MAF or SD mode?
Old Dec 22, 2005 | 11:59 PM
whiteLS1's Avatar
well i was reading through some old post about this code and found out i need to check some fuses and i found one bad go firgure. all better
thanks matt
