hi vs. lo octane timing tables
Old Apr 13, 2002 | 01:03 AM
patSS/00's Avatar
Default hi vs. lo octane timing tables
I've seen some posts recently about there being 2 timing tables, for high and low octane. Is there a way in autotap to tell which table is being used?
<small>[ April 13, 2002, 01:04 AM: Message edited by: patSS/00 ]</small>
Old Apr 13, 2002 | 08:46 AM
MIGHTYMOUSE's Avatar
Default Re: hi vs. lo octane timing tables
ask somebody with edit what the max advance is on the low timing table.. i think 24*? compare that to what you are getting..
if you are running 93 it SHOULD be on the high one unless you have really really bad 93 where u are.
it is always relearning and readvancing the timing so if it is low it should go up to normal with more octane.
Old Apr 13, 2002 | 02:05 PM
patSS/00's Avatar
Well, around 24 is what I've been getting lately, even though it used to be higher. I can only get 92 octane here, but I can add some xylene and see if that affects the timing.
Old Apr 13, 2002 | 06:06 PM
ToplessTexan's Avatar
I haven't seen any parameters that would indicate this. I know (on the C5, not sure about F-Body) that adding fuel (like 5 gal or so) triggers the switch to the high octane table. It falls back to the low octane table if it's unhappy.
Old Apr 13, 2002 | 07:12 PM
99 WS6's Avatar
I read somewhere that the computer resets to the high octane table when there is a change in the fuel level. It assumes that you got some bad gas and resets when you fill up again.
