MAFT question
What is the best way to use the MAFT, my friend has a autotap would that do the job or should i just take it to a dyno.
What should the MAFT be set at??? i have no clue how to use one of these, but i know it is what i need to get every ounce out of the mods that i have done so far.
My mods are BGRA, MTI lid, ported MAF ends, a couple of free mods and a SLP y-pipe. This is on a 01 WS6 A4, my best mph in the 1/4 is 107.5 and i know there is more power there with my air/fuel set right, so any help anyone could offer would be great help to me <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
<small>[ April 13, 2002, 03:58 PM: Message edited by: Red Dragon ]</small>
<strong>you have to A-Tap it to know what settings.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I understand all that, but what are the normal settings for the o2's and the ltrims, so i know if im off or not.
about where your readings should be, I really cant answer that accurately, I just got autotap myself, and am still taking logs, never started tuning.
try sorting through this forum, there is a lot of info (and reading).
When tuning with the MAFT, your first objective is to get both L-trims (Bank 1&2) as close to zero (0) as possible. For example, at idle, if your averaged L-trims are below zero you have a "slight" rich condition @ idle. If your averaged L-trims are above zero you have a "slight" lean condition.
You have to tune the BASE setting before doing anything with the WOT setting. This is crucial because if you don't you end up just chasing your O2's and hurt performance instead of enhancing it. I'll give you an example form my '98 SS. Before I used the MAFT, my averaged O2's were in the .865mv range @ WOT and I had slight pinging which hindered performance as well as Knock Retard of 3.0 degrees. I was lean. At idle my L-trims were as high as + 11. Again, this is way lean. With the BASE MAFT set on + 4% rich and WOT set to + 6%, my L-trims @ idle went to "0" and WOT O2's averaged .880mv. I picked up a solid 10 rwhp along with a PACE MAFS using this mod. Hope this helps explain some things.
Also I see in your sig trent that your MAFT is a L52 version. Is there another version out there, or are they all about same <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<small>[ April 20, 2002, 12:03 AM: Message edited by: Red Dragon ]</small>
Another thing, I went to ramchargers site and looked up the MAFT, when reading the description it had a pic too, and after looking at the pic I see what gets pluged into and where. The question is what about the stock connections you unplug so the MAFT can be plugged in, what do you do with those, I know you just do leave them hanging. do you close them off or tie them down or what cause that worries me
