another code delete question....
Old Apr 14, 2002 | 03:09 PM
Slow Z28's Avatar
Default another code delete question....
well, i asked before about the emmissions test and the code deletion. i got a response that if the code like AIR and EGR are deleted, it would show up on the emmissions scanner. so what do you '98 guys do if you add an ls6 intake and ahve to take emmissions? is it ok to have one or two codes missing or "activated"? i'm in the middle of a header install and was wanting to just rip out the egr stuff. and then when it comes time for ls1-edit, just have that code removed. thanks a ton!
Chris
Old Apr 15, 2002 | 10:21 AM
Ragtop 99's Avatar
Default Re: another code delete question....
One strategy is to leave the codes functional, but change the EGR and AIR to operate only at conditions outside of normal operating parameters (e.g. on at -40 and off at -39 coolant temp)
Old Apr 16, 2002 | 12:59 AM
Slow Z28's Avatar
wow, that's a good idea. you guys are so smart. hhhehe. anyways, so would i do that for both AIR and EGR systems? and what "parameters" do i look for with the LS1-edit? thanks!
Chris
