Ltrims are jacked up...
Your L-trims are extremely lean @ idle. I would encourage you to buy a MAFT to bring them down. Even though WOT looks good, riding around part throttle as lean as you are isn't good. The MAFT will allow you to adjust your L-trims to as close to "0" as possible. This will have very little to no impact on your WOT blasts.
I would go with SVO 30 injectors which are only about $220 for a set and then use a MAFT to dial it a bit leaner thus you assure good WOT timing, and lower injector pulse width which PCM can control better then long on times.
Best case is instead of MAFT is to use LS1-edit and do a full custom tune of other functions as well as AFR issues.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JimTA:
<strong>15-20 at idle for Ltrim 1 and Ltrim 2. The car runs great, .890-.910 at WOT and 0 KR...but it seems way lean driving it around at light and part throttle. Do I need to correct it with a MAF-T or bigger injectors? I have a 98 LS1 with full boltons and a cam.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Thanks for the responses.
