Getting a B1 with stock heads.....
Old Apr 16, 2002 | 01:32 PM
ASR OFF's Avatar
Default Getting a B1 with stock heads.....
What exactly has to be done to the stock programing to fully take advantage of the B1 cam? I will be running stock heads, SLP LT headers with RT cats and Borla cat back exhaust. I know it will run good w/out programing, but eventually I would like to really take advantage of that cam. Is this something that the HPP3 can take care of?
Old Apr 16, 2002 | 02:06 PM
Ragtop 99's Avatar
Default Re: Getting a B1 with stock heads.....
You can use the HPP3 to raise rev limiters/shift points and a MAFT to adjust A/F ratio. If you have an A4 you may perfer to buy Edit so that you can also raise the idle, change TCC lock-up, and adjust your downshifts.
