MSD Window Switch issue/problem
I gave it a constant ground, a constant power, and tapped the Tach line (Pin 10 on PCM , white). I cut both loops.
I connected a voltmeter to the yellow output wire. When connected to a positive and this wire it read at 11.5 volts which means the wire is providing a ground.
At 3000 RPM it registered 13.5 volts... did I wire something up wrong here? Or is it supposed to behave like this?
at 3000 rpm's (or even idle, with the car on) the voltage is about 13.5-14
So thats the right reading to get
Ryan <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Right now it's providing a constant Ground
to test the switch easier, use a light (test light of some sort). also, make sure you are using the window switch to activate a relay, that triggers the item your activating (nitrous 'noid i assume). the window switch is not designed to take the amps of those noids, especially 2 of them.
