LS1 edit to richen at WOT below 4krpms
Old Apr 23, 2002 | 09:45 AM
SAM98WS6's Avatar
Default LS1 edit to richen at WOT below 4krpms
OK experts, in your opinion what is the best table to modify to richen up WOT below ~4k rpms. On the dyno the car starts out at WOT at 15:1 A/F but settles to 13:1 at about 4k which is just about perfect with zero KR and 30 degrees advance.
Thanks
Old Apr 23, 2002 | 11:20 AM
ChrisB's Avatar
Default Re: LS1 edit to richen at WOT below 4krpms
PE vs RPM should be the only table you use for WOT A/F ratio changes (assuming a closed loop car).
Chris
Old May 15, 2002 | 03:17 PM
Scalpel's Avatar
Chris, do you just mulitply through by a certain percentage then in the PE vs RPM table? Thanks.
