logging WB O2 info in your PCM
Anyway, has anyone considered the WB-O2 data logging approach where you swap an existing PCM input for the WB-O2 data (a voltage range representing an AFR range) and then proceed to monitor the variables (TPS @ WOT, WB-O2, timing adv etc. and then caculate AFR as "Shawn" has been doing for quite a while with his excel spread sheet?
Tks
Rick
