Does ecm use oil pressure?
Old Apr 26, 2002 | 01:22 PM
70 LS1's Avatar
Conversion master
Default Does ecm use oil pressure?
I want to pull out the oil pressure sending unit and replace it with the one from to 70 corvette so I can use the stock gauge. Does the ecm use oil pressure for anything? Will disconnecting it cause any codes?
Old Apr 29, 2002 | 07:02 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Default Re: Does ecm use oil pressure?
My guess is the pcm doesn't "use" the pressure for anything but it is monitored and there are at least 4 codes that have to do with the sensor circuit. Probably so it can be determined if the circuit/sensor is malfunctioning. PO520-PO523.
