timing low please help
And my understanding is when you use a MAFT to tell the PCM there's more airflow than there really is, the PCM will adjust richer (+ ltrims) and lower timing. To get higher timing, you have to get higher fuel delivery (bigger injectors or higher pressure), to cause a rich condition, which will cause the PCM to adjust leaner and raise timing.
