TPS Voltage via ATAP
Old May 7, 2002 | 02:22 PM
BlackhawkSS's Avatar
Default TPS Voltage via ATAP
okay well i check it with a voltmeter and its 4.7 volts, but when i check it with atap it says 88.6 DEGREES instead of volts. i have checked it with atap before no prob, so why does it read it in degrees now? can i change it to volts?
Jerry
Old May 9, 2002 | 07:33 PM
Ragtop 99's Avatar
Default Re: TPS Voltage via ATAP
Look again at the list of ATAP choices. I thought I remember seeing both.
I hate the fact that you can't create a configuration table w/o being hooked up to the car. Otherwise I would look.
