getting LS1 edit tune 2morrow- please help
Mods are: Air lid, bellows,160ish stat, offroad y-pipe, YANK ST3200 converter.
I am getting the dyno tune tomorrow and was looking for some advice from experience. Wideband O2 will be monitored and air fuel will be adjusted, but my main concern is with improving the driveabilty of my ST3200. I have a funky idle in drive(occansonaly) and has stalled in reverse.
Delete Torque Management
Delete Rear O2 sensors
Increase timing to 28-30 degrees
Raise minimum speed to upshift to 4th gear to 40 mph
Raise minimum speed for converter lock-up in 4th gear to 40 mph
Raise minimum speed for converter lock-up in 3rd gear to 35 mph
Reduce amount of throttle input required for converter unlock in 3rd and 4th gears at speeds below 60 mph
program for a faster downshift (less TPS required)
raise upshift speeds in 2nd gear by 3 - 5 mph at 18% TPS and less
Fan Settings
fan 1 on/off at: 185 / 175
fan 2 on/off at: 195 / 186
Delete P0300 Code
Raise idle
37% TPS, the converter unlocked in 3rd and want the car to downshift from 4th to 3rd because I want the car to start moving quickly.
Any advice on any of these is appreciated, I found them in another post. Please help
Thanks
Marco
28 - 30* of timing may be too high on an '01.
i'd bring fan 2 on a few degrees sooner. I don't see any advantage to the car going over 190 degrees with a 160 T-Stat.
