eliminating surging with LS1EDIT???
I have access to LS1Edit. Any Ideas? We've tried rasing the idle but it doesn't seem to make much of a differance....
I've got two big *** holes in my blade...
I just wish I could lower my idle, I idle at like 1050rpms. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
ARE 422ci IRON setup
Check your IAC count when fully hot.
I'd turn the idle set screw 1 full turn and see if that helps. If it helps a bit, then enlarge your TB hole by 1/32". If that helps but doesn't cure it, I'd drill a second small hole, say using a 1/8" bit and go from there. Watch your IAC count so you don't over do the hole size.
