First ATAP Got some ???s
Then I drove around and watched my knock retard, and it was 0.
Now my questions: What should my O2 sensor readings be, and which ones should I look at (B1S1, B2S1, B1S2, B2S2)? What should my timing be? What am I looking for.
My car is fairly stock. Engine mods are Catback, TB bumpstop mod, FRA, Ported TB, Lid, and !CAGS, de-screened MAFS.
During cruise, there is no use to monitor your O2's (all you'll see is them switching from rich to lean). Depending on what you want to do, monitor RPM, timing and KR and then add Long Term Fuel Trims for both Bank 1 and 2 as well as what fuel "cell" you're in. You could then monitor Misfire current cyl 1-8 to see how you're running. (Check in the FAQ section on ls1.com, there is a good thread up there on ltrims)
At WOT, RPM, timing, KR and both of your front O2 sensors B1S1/B2S1 are what you want. From there, you can add different things depending on what you want to do. MAF flow can help you gauge different mods, base injector pulse widths to see how high a % duty cycle you're running, etc. This lists are many. I've got different setups depending on whether I'm monitoring drivability, checking the fuel system status, verifying WOT shift points, etc.
Have Fun!
Mark
<small>[ May 09, 2002, 09:07 PM: Message edited by: J&JsTA ]</small>
