shift point settings...HPP3....
Old May 12, 2002 | 02:56 PM
Slow Z28's Avatar
Default shift point settings...HPP3....
i know every car is different. i'm just looking to see what some of you guys/gals used for **** point settings on the programmer. you can see the mods in my sig below(the '98Z). i've seen some people use like a +2, +2, 0. Sometimes even higher, but i still have the stock motor. Then other times i've seen +2, -2, 0. So unless it was a mistake in typing, what would be the purpose of putting the 2-3 shift lower? Thanks for anymore advice
Old May 12, 2002 | 07:53 PM
Ragtop 99's Avatar
Default Re: shift point settings...HPP3....
I would start with +1 on 1-2 and +3 on 2-3 and experiment from there with the goal of shifting at 6200 (asuming a stock valvetrain).
Old May 12, 2002 | 09:13 PM
LS1 JAY's Avatar
As of right now, mine is set at +2,0 and 0 I moved up the 1-2 because it was shifting early(now it shifts at 6,000), 2-3 is always at 6,000 - 6,100 so I left it alone.
Old May 12, 2002 | 09:29 PM
Slow Z28's Avatar
thanks guys. i still have the stock drivetrain. so i know not to rev it too high. anymore suggestions? any ideas on why the negative shift points?
