Help with LS1 Edit
Old May 12, 2002 | 10:13 PM
DBerry's Avatar
Default Help with LS1 Edit
They said three weeks so I should get it this week.
Since I'm starting back with stock programing what paramaters should I be changing?
The car is an M6 so I don't have to change any of the trans settings. The cam is a 228\228 with .547 or so of lift. The heads have 2.02 intake valves and 1.57 exh. Y- pipe is off-road. I think everything else is in the Sig.
<small>[ May 12, 2002, 10:15 PM: Message edited by: DBerry ]</small>
Old May 15, 2002 | 08:04 AM
DBerry's Avatar
Default Re: Help with LS1 Edit
Did I make you guys mad ro something? Nobody responds to my posts. What's up I need some help guy's?
<small>[ May 15, 2002, 08:04 AM: Message edited by: DBerry ]</small>
Old May 15, 2002 | 09:01 AM
XTREMEZ28's Avatar
i am in the same boat... should hopefully get my ls1 edit this week just in time for the heads/cam install this weekend.... i want to know of a good checklist to go through so that i make sure and get everything changed that needs it....
Old May 17, 2002 | 11:07 AM
adam12's Avatar
Guys,
You need to run autotap or Ease to figure out what your cars are doing. You need to look at your ltrims and WOT AFR. Once you have some logging done, then you can start to make changes with ls1-edit. I would start with the ltrims to see if your cars are running rich or lean. You can add timing if you like.. some people take there cars from 28deg at wot to 30deg at wot. Then you would log KR( knock retard). Hope that helps. We are not ignoring you. You just need to provide some data for people to look at. Get autotap or Ease.
