Can temporary no rear O2 sensor code be fixed with ATap?
Old May 16, 2002 | 11:21 PM
BLUEBYU's Avatar
Default Can temporary no rear O2 sensor code be fixed with ATap?
I am driving from a cam install to exhaust install without sims but will have the sensors installed at that time. Is this possible and then clear it permanently with ATap.
Thanks for any ideas here.
Old May 16, 2002 | 11:46 PM
Brother J's Avatar
Default Re: Can temporary no rear O2 sensor code be fixed with ATap?
Sure, ATAP will clear out your DTC's. You will probably find that you can drive for a goodly amount without setting codes for a missing rear O2 sensor.
