SES code 1133 need help ???????????
Old May 18, 2002 | 07:58 AM
boomcase's Avatar
Default SES code 1133 need help ???????????
I keep getting a code 1133 on my scanner. it explains bank 1 oxygen senser getting wrong signal. could someone please explain what that exactly mean in backyard mechanic terms.doesnt mean to replace the first sensor or the second one or something else please help. thanks
Old May 19, 2002 | 11:54 AM
Ryan K's Avatar
Pathological Modifier
Default Re: SES code 1133 need help ???????????
If you have not changed anything recently that may have damaged wireing or any connections, that code means that your Drivers side front O2 sensor has gone bad and needs to be replaced. Before replaceing the sensor check: Wiring, exhaust leaks within 6-10" of the sensor, and make sure you didn't use any silicone which may have contaminated the sensor.
Ryan K.
