autotap connectors
Old May 21, 2002 | 04:17 PM
BigBake's Avatar
Default autotap connectors
I just purchased a new Laptop and it does not have a 9 pin serial port. So I went to Radio Shack and purchased a 9 pin to 25 pin adapter, this did not work. Anyone else have any ideas what I could use to connect to my laptop? It has USB and a 25pin serial connector. I also used the adapter on my home PC and it did not work on it, but the it has 9 pin serial and of course it works there so it has something to do with the adapter plug. Any suggestions?
Old May 21, 2002 | 04:31 PM
Team ZR-1's Avatar
Default Re: autotap connectors
The 28 pin is not a comm port, it is for printers,
you need to get a USB to serial comm cable, about $40 I think.
Don't be surprised if autotap drops the link or will not connect, thats a norm with that scanner :-(
Old May 23, 2002 | 07:14 AM
jpatrick's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Team ZR-1:
<strong>The 28 pin is not a comm port, it is for printers,
Don't be surprised if autotap drops the link or will not connect, thats a norm with that scanner :-(</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That is not the norm with the Autotap. The Autotap has no problems keeping a link. There are issues with some USB to serial adaptors though. Some of them don't work correctly, and thus cause the Autotap to loose connection.
Jeff
Old May 23, 2002 | 08:16 AM
Beth's Avatar
I had the same problem. I called B&B Electronics and ordered Model # UC232A, USB to Serial. I don't have any problems with the connection.
Beth
Old May 23, 2002 | 07:40 PM
BigBake's Avatar
Thank you for the suggestions.
