P1153 & C1283 What To Do?
Old May 24, 2002 | 04:21 PM
Ray'98's Avatar
Default P1153 & C1283 What To Do?
I've got two nagging error codes, P1153 and C1283. The O2 sensor ones started after major motor and header work. Tried everything to get rid of them but they keep comming back.I may have to resort to deleting the codes from the program. Is this possible to do with LS1edit? Any suggestions aside from this as a fix?
The C1283 started after a diff change, 3.90's. I get all the active handling warming up messages as well. Is it possible to get this error if the wrong ratio was put into the program or not changed at all? Had 3.43's origionally.
Your comments will be appreciated.
Old May 25, 2002 | 05:18 PM
R U A LS1's Avatar
Default Re: P1153 & C1283 What To Do?
TTT im curious
Old May 29, 2002 | 08:33 PM
2kredCSS's Avatar
I've had the p1153 code every since I have installed my headers... can't get it to go away either. its extremely annoying. I do know its the pass side pre cat sensor? If you find out anything please let me know!
