LS1 edit... who has it
I need to get LS1 edit. I was planning on just getting A-tap, but it seems it can only point you in the direction of what might be wrong.
I already dropped the $2500 on the laptop.
I think LS1 edit may be overkill for what I need... I'm not doing heads and cam, and it looks like I could/would probably mess up more than I fix. I just wanted to read codes and sensors, but it would be nice to not have to buy things like an MAFT and such.
Question #1:
Which vendors carry LS1 edit.
Question #2:
Where can read more about the program and less about people's problems??
then Viper posts
"ATAp is a must; it monitors what is going on. MAFT and LS1Edit are programs that allow you to make changes. MAFT allows you to +/- fuel at cruising and WOT"
So LS1 Edit doesn't read codes and sensors...?
<small>[ May 27, 2002, 12:22 PM: Message edited by: Ross ]</small>
The above picture is from EFILive V5 so simple to use, this is the charts page, showing your car in real time monitoring mode.!!
If you can wait till the 1st July only 4 and bit weeks away, you can use EFILive V5 to read all you diagnostic codes and problem your car might be having.
The company that selling the software is at EFIliveV5 Software
If you purchase Atap and you still would like to try EFIliveV5 you can purchase the software SO it can work from your Atap cable 2 programs for one cable no bad.
Price to Purchase
USD $95.00 until September 30, 2002.
<small>[ May 27, 2002, 04:40 PM: Message edited by: SIKLS1 ]</small>
