Is there a retorque procedure for knock sensors?
Old May 27, 2002 | 01:59 PM
Stu's Avatar
Stu
Default Is there a retorque procedure for knock sensors?
Or is it just on a LT1?
Thanx, Stu
Old May 28, 2002 | 02:27 AM
ChrisB's Avatar
Default Re: Is there a retorque procedure for knock sensors?
Are you referring to torqing to a lower value to decrease sensitivity? You would probably have better luck putting a couple of wraps of teflon tape on the sensor if that is your goal.
Chris
Old May 28, 2002 | 01:14 PM
SSINFUL's Avatar
There is a torque value in Helm. You certainly don't wanna decrease the torque so they rattle around!
The best way to desensitize them is to have the PCM fiddled with.
