Please Help with SHIFT LIGHT on LS1 engine
Old May 27, 2002 | 02:42 PM
A Mustang's NightMare's Avatar
Default Please Help with SHIFT LIGHT on LS1 engine
I need help on how to istall the shift light,for my LS1 camaro.Got the blk & red wires hook up.But I dont know were's the RPM box so I hook up the green wire.
Old May 27, 2002 | 04:45 PM
felton316's Avatar
Default Re: Please Help with SHIFT LIGHT on LS1 engine
1999, 2000, 2001, and 2002 model F-Body's should locate the number ten (10) pin. The wire should be white in color. 1998 model F-Body's should locate the number 35 pin (in the upper cover) and the wire should be white in color.
This install can be found at: http://eric.virginia.com/install_uni...ht_install.htm
