OBD2 Scanner Help....
Old Jun 4, 2002 | 09:49 AM
rcclass's Avatar
Default OBD2 Scanner Help....
I have the OBD2 Scanner/program from Car Code, (www.obd-2.com). It works wel with every Gm vehicle I've tried it on but My '01 Firehawk. It doesn't make the connection on the Hawk.
Is there a fuse for the OBD2 port?
It is annoying. Has anyone used this program? Are all of the cables/connectors the same, would the AutoTap program work with this cable?
Thanks,
Roger <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jun 4, 2002 | 10:08 AM
98blackSS's Avatar
Default Re: OBD2 Scanner Help....
The autotap program will not work with the OBD-2 cable. The diag port is fused. You can verify port power by measuring voltage from pin 16 to ground.
What are your gateway settings and what errors are you getting?
Port diagram: http://www.elmelectronics.com/GIFs/J1962.GIF
<small>[ June 04, 2002, 10:10 AM: Message edited by: 98blackSS ]</small>
