Please verify programming checklist for h/c pkg.
Old Jun 7, 2002 | 07:58 AM
Brownie's Avatar
Default Please verify programming checklist for h/c pkg.
Could you guys please verify this programming checklist for my upcoming heads/cam/intake/exhaust package.
Car:
99 TransAm WS6 M6
Package:
GTP SII Heads (918s)
TR 224/112 cam
LS6 Intake (no egr)
FLP Long Tubes
ASP Pulley
160 Thermostat
Programming Checklist (having pcm programmed with ls1 edit on a dyno with wideband):
Air/Fuel
Timing
Idle Speed
Rev Limiter
Random Misfire Code (PO300)
Cags
Egr deleted
Rear O2 deleted
Performance Enrichment (not sure what this is??)
Speed limiter
Torque Management
160 Thermostat
Fans
Gearing (won't need this now since I will still have 3.42s for a while)
Anything I have missed?
Any suggestions?
Can I have the original PCM programming stored off so that it can be restored?
Does ls1 edit have the ability to lock the pcm?
Really appreciate your help.
Thanks,
Mike
<small>[ June 07, 2002, 08:01 AM: Message edited by: Brownie ]</small>
Old Jun 7, 2002 | 08:34 AM
Ragtop 99's Avatar
Default Re: Please verify programming checklist for h/c pkg.
Delete the AIR trouble codes
Old Jun 7, 2002 | 09:57 AM
Brownie's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ragtop 99:
<strong>Delete the AIR trouble codes</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks.
Could you elaborate a little for me. Need a little education on this.
Mike
Old Jun 7, 2002 | 05:23 PM
Brownie's Avatar
Anyone??
If I got up all then just give me a "sounds good" if you could.
Thanks,
Mike
Old Jun 9, 2002 | 07:43 PM
Brownie's Avatar
TTT
Old Jun 9, 2002 | 07:51 PM
Ragtop 99's Avatar
Those are the codes for the AIR system that you may want to remove when you do headers.
