Anyone using POWERLOADER that TTS sells?
The PowerLoader is a lot of hype. Plus you have to wait FOREVER to get it from TTS.
AutoTap is okay for obtaining the data but Ease is far superior. Better interface and better connection.
If you decide to use a MAFT (which works quite well) you will still need Ease to obtain the data. You will also need to get data from your PCM if you use LS1 Edit. The main advantage of using LS1 Edit is there are so many things that you can control (engine, tranny, fan on/off temps, etc) that you can't with the MAFT.
After he has fine tuned your car, you can still tweak some settings yourself if you have LS1 Edit. Or, you could have a summer flash file and a winter flash file with different settings for temperature. With your own LS1 Edit you have much more flexibility.
