C5 IAC count vs Fbody IAC count
Old Jun 7, 2002 | 03:58 PM
Scalpel's Avatar
Default C5 IAC count vs Fbody IAC count
I'm coming up on a cam install in my C5 and I'll need to drill the TB to get the proper IAC count. On the Fbody's you want your IAC count to be in the high 30's to low 40's at idle. I just tested my C5 (stock cam, etc) to see what it was before and mine reads 107-109 at operating temperature. Since the C5's have a throttle by wire and F-Bodies have a throttle by cable is this why I have such a different IAC count? Thanks.
Old Jun 8, 2002 | 09:24 AM
nevrenuf's Avatar
Default Re: C5 IAC count vs Fbody IAC count
Yes, IAC counts run higher on the Vettes.. typically the h/c guys end up with holes in the 3/16 to 7/32 range.. too large and engine takes forever to settle down to an idle. too small and you stumble. You can always start at 1/8 and work your way up..
Old Jun 8, 2002 | 01:15 PM
Scalpel's Avatar
Tom, what is your IAC count at idle (@ operating temperature)? Thanks.
Old Jun 9, 2002 | 11:23 PM
Scalpel's Avatar
TTT
