How to adjust w.o.t. timing with edit?
Old Jun 6, 2002 | 10:43 PM
CB99SS's Avatar
Default How to adjust w.o.t. timing with edit?
Which tables do you adjust for w.o.t. timing? You have .08 gm/cyl to 1.0 gm/cyl on the left side of the table and 400 rpm to 8000 rpm on the top of the table for both the high and low octane tables. Jayson at MTI sugested I remove 3 degrees at w.o.t. when I use my NX 150 shot.
Any help would be appricated.
Thanks
Old Jun 9, 2002 | 04:38 PM
383LQ4SS's Avatar
Default Re: How to adjust w.o.t. timing with edit?
I am going to put this in the Computer & Tuning section. There are lots of people familiar with LS1 Edit there.
Old Jun 10, 2002 | 12:06 AM
Ryan K's Avatar
Pathological Modifier
In the High octane table;
I highlight the area from .6 and higher then over to 8000 rpm then at the bottom check the box to selected cells. Then in the box on the bottom put in -3 and click the add value box.
It should lower the selected cells by 3 degrees. Click apply and you are done.
Ryan
