SVO 30# injectors
Old Jun 10, 2002 | 08:02 AM
2000 Camaro SS's Avatar
Default SVO 30# injectors
If you install new 30# injectors (Ford) will you have to re-program the computer for all of the new fuel? Will the computer learn on it own?
Old Jun 10, 2002 | 11:22 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Default Re: SVO 30# injectors
I'm going to put a copy of this in the tuning section as well.
__________________
Old Jun 10, 2002 | 01:51 PM
Ragtop 99's Avatar
running rich is the result of using bigger injectors w/o programming.
Old Jun 11, 2002 | 12:13 AM
Max@Cartek's Avatar
You will have to reprogram. the pulse width will change for the same amount of fuel. Since it's a bigger injector the pulse width will be smaller for the same amount of fuel delivery.
Old Jun 11, 2002 | 12:24 AM
With out re-programin would the car have small low RPM backfires? I just put in the injectors and have to go get the car reprogramed this Friday but right now it runs RICH. Would this be the problem?
