Help me out with dyno, A/F, and ATAP data.
Below is a summary of the data I have.
Dyno 379 rwhp, 372 rwtq (SAE corr.)
(Pulled 386/375 on third pull but I don't have Atap data for it)
A/F ratio measured with probe in tailpipe (is that the correct way?)
Maintained about 13-13.2 then dropped to about 12.7 above 6k rpm.
ATAP,
32 deg timing at throttle tip in and 23.5 by 6k rpm, 0 KR
O2's B1 .989-.980 B2 .1019-.1002
Coolant temp 196-198F
Unfortunatly that's all the Atap data I have, we were having connection problems.
Can someone tell me how this looks?
It appears to me the A/R ratio data contradicts the O2 readings.
Timing seems a little low in the upper RPM's. Don't make any correlation between O2 readings and AFR readings. You may find a correlation between the two on your vehicle, but you shouldn't tune the car using your O2's.
Would measuring at the tailpipe sway the results toward rich or lean?
Timing: If your ported heads were milled for more compression the PCM will "like" more spark advance than with stock compression. What year is your car? I've heard the '02 (and possibly the '01s) have less timing at WOT than the earlier years.
