HELP W/ HPP III INSTALL
If you're running a stock valvetrain I don't believe I would bump the rev limiter up.
Setting the shift points might be useful, only testing will confirm if they help. I found changing the 1-2 & 2-3 shifts helpful after TC install.
As far as shift firmness settings I can't help as mine are stock. Some say increasing the shift firmness w/HPP3 might cause premature wear; some say the increase in line pressure couldn't possibly be enough to cause any damage. I have no opinion on that.
Hope this helps.
Not sure about other years, but I believe the stock rev limit is already at 6200 rpm on the 2000 F-Bodys. I know my 2-3 shift is a little over 6150 with a +2 setting via HPP3. I'm using a +4 setting on the 1-2 shift but the actual shift rpms are kinda low sometimes due to wheelspin. It's one of those "experiment and see" kinda things. Took me several tries to get mine optimized.
<small>[ June 13, 2002, 07:40 AM: Message edited by: gwj ]</small>
