WOT timing is real low...
Old Jun 12, 2002 | 02:24 PM
black00WS6's Avatar
Default WOT timing is real low...
I took some a-tap runs and found that my WOT timing is only around 18-19. What should this be at? I have LS1edit and would like to increase it before it gets dynoed this saturday. I know I go to the high octane tables, but what do i change after i get there??
Old Jun 12, 2002 | 02:48 PM
TrentSS's Avatar
Default Re: WOT timing is real low...
You also need to log Knock Retard. I would look at my L-trims at idle on both banks as well. If your timing is low @ WOT then most likely your getting some K.R.
Old Jun 12, 2002 | 03:19 PM
Phate's Avatar
It would help to know what year as well, the 01-02s have lower timing due to a more aggressive cam.
Scott
Old Jun 13, 2002 | 06:20 AM
black00WS6's Avatar
well I had a T1 cam and it was around 17-18 with 0 KR, then I just installed the TR230 cam last weekend and it actually raised a bit to 18-19, still with 0 KR at WOT.
Old Jun 13, 2002 | 04:47 PM
MelloYellow's Avatar
Your PCM thinks you have bad gas and put you on the secondary timing table most likely. Go add 5+ gallons and see if the timing improves.
