Starting problems!
Old Jun 14, 2002 | 12:15 AM
equinoxlb's Avatar
Default Starting problems!
Weird problem last night. When I turned the key everything sounded ok but car wouldn't start. No sign of ignition at all. It turned fine and the battery was ok. Tried 10-15 times all of a sudden it started and ran fine to the store. Came back out and it started first try, ran for 2-3 seconds and died. Same thing only this time nothing for 25-30 attempts. Weird thing was that power windows, radio etc worked without the ignition on and key out. Finally locked and unlocked the car a few times and, again, all of a sudden it fired up and ran normal. I later thought it may have been the theft deterrent system that kicked in somehow. Anybody experience this before?
Old Jun 14, 2002 | 12:17 AM
99taws6's Avatar
Default Re: Starting problems!
Sounds Like a VATS problem.... Try cleaning the resistor pellet on your key and cleaning the ignition tumbler with some electronics cleaner....
Old Jun 14, 2002 | 12:30 AM
equinoxlb's Avatar
Thanks. I was gonna do that and I've heard about key problems before but has always been described as a completely dead car. Mine was not, the starter turned normally.
